Unable to run the CDF Transformation job created
I’m going through the Python SDK- CDF Transformation module in the  DATA ENGINEER BASICS - TRANSFORM AND CONTEXTUALIZE course.
While I’m able to create the Transformation  object, I’m unable to run due to some Authentication issues.
When I’m trying to run using the below code:
client.transformations.run(asset_transformation.id, wait=False)
I’m getting the following error :
Transformation job could not be created.
Error code: 403
API error: Invalid source/destination credentials: Could not authenticate with the OIDC credentials. Please check your credentials.
Request ID: 1a470c41-9001-989b-8f97-a2aaefdfd098
Is it due to some recent change in the Oidc credentials defined in the notebook currently?
Best answer by Gaetan Helness
@Philips
Could you complete the last step 4 Clean up resources and start from scratch, or at least delete the transformation
client.transformations.delete(external_id=[f"{PREFIX}-assets", f"{PREFIX}-ts", f"{PREFIX}-dp"])
and recreate it.
The previous secret that was not working has been stored in the transformation and therefore the transformation needs to be recreated
Sofie Haug
Forum|alt.badge.img+7
  • Cognite Academy Instructor
  • 156 replies
  • April 24, 2023
Hi @Philips
Could are able to authenticate in the first cell in the notebook?
Thanks for your feedback.
It seems like an access right issue.
Did you generate a secret and added it to the code?
Did you encounter any errors earlier in the notebook, like in the first steps on the
print(client.iam.token.inspect().projects)
And what information do you get via
print(client.iam.token.inspect())
  • 12 replies
  • April 25, 2023
Hi @Sofie Haug , @Gaetan Helness
Thanks for the response.
Yes, I was able to authenticate the first cell in the notebook (i.e. I added the secret that i generated in the course).
When this statement is run,  print(client.iam.token.inspect().projects) I encountered no error.
Following the output I got:
[{ "url_name": "cdf-fundamentals", "groups": [ 7233047623736400 ] }, { "url_name": "infield-training", "groups": [ 1376085367190226 ] }, { "url_name": "publicdata", "groups": [ 1701516184810448, 4860375157547584 ] }, { "url_name": "de-transformations", "groups": [ 3974891759857484 ] }]
The information I get via below is attached.
best regards,
philips
roman.chesnokov
It seems like an error with generating secrets from the course. @Rahul Kumar , could you look into it?
Yes I agree with Roman
@Philips under the section Create credentials for use in Transformations, could you try to run this code?
This will try to authenticate with the client secret provided above in the notebook
from cognite.client.data_classes import OidcCredentials
creds = OidcCredentials(
        client_id = CLIENT_ID,
        client_secret = CLIENT_SECRET,
        scopes = " ".join(SCOPES),
        token_uri = f"{AUTHORITY_URI}/oauth2/v2.0/token",
        cdf_project_name = COGNITE_PROJECT
cnf_secret = ClientConfig(
    client_name="test-client",
    base_url=f"https://{CDF_CLUSTER}.cognitedata.com",
    project=COGNITE_PROJECT,
    credentials=creds,
client_secret_auth = CogniteClient(cnf_secret)
print(client_secret_auth.iam.token.inspect())
The token inspect you printed is actually authenticated with your user, but great that works
  • 12 replies
  • April 25, 2023
Hi Gaetan,
On running the code you gave, I’m getting below error.
AttributeError: 'OidcCredentials' object has no attribute 'authorization_header'
Forum|alt.badge.img+6
  • 61 replies
  • April 25, 2023
Hello Philips,
Please generate the new secret in the course  and use newly generated secret for auth in the code
Regards
Kumar
You can then test the newly generated secret via
from cognite.client.credentials import OAuthClientCredentials
client_secret_auth = CogniteClient(ClientConfig(
    credentials=OAuthClientCredentials(
    token_url=f"{AUTHORITY_URI}/oauth2/v2.0/token",
    client_id=CLIENT_ID,
    client_secret=CLIENT_SECRET,
@Philips let us know when you had a chance to test it out, but generating a new secret should fix the issue
  • 12 replies
  • April 26, 2023
@Gaetan Helness , The above code did run without any error.
But when I’m trying to run the transformation (given below), the error remains the same as before:
Error:CogniteAPIError: Invalid source/destination credentials: Could not authenticate with the OIDC credentials. Please check your credentials. | code: 403 | X-Request-ID: 42d5a64d-d981-9154-8e9c-e302a2082e38
@Philips thanks, did you regenerate a secret, updated it in the code and reran through the notebook?
What was the output of
The problem is coming from the secret according to the error message.
And if you can also send the output of
asset_transformation = client.transformations.retrieve_multiple(external_ids=[f'{PREFIX}-assets'])[0]
  • 12 replies
  • April 26, 2023
Yes, I updated the secret in the code. The output is attached
  • 12 replies
  • April 26, 2023
Output is attached
Thanks, everything looks quite good, it is hard to troubleshoot what is wrong.
We will have another look through your attachments and get back to you
@Philips
and recreate it.
  • 12 replies
  • April 26, 2023
Yes, the cleaning up the transformation did the trick.
It is running fine now,
Thanks a lot everyone for the prompt support!
Thanks for your patience and help for troubleshooting.
Kudos to @roman.chesnokov , @Sofie Haug and @Rahul Kumar for the help as well
