I have a transformation that is to write to a new dataset as seen here:
SELECT
concat('CWS:',loc) as externalId,
IF(parent_loc='' OR parent_loc IS NULL, '', concat('CWS:',parent_loc)) AS parentExternalId,
CAST(lastUpdatedTime AS STRING) AS name,
to_metadata(*) AS metadata,
description AS description,
7089382776719091 AS dataSetId
FROM `CWS-Assets-DB`.`CWS-Assets-Tbl`
The Preview seems to work fine.
When RUN: I get following error:
Request with id 96f4a082-9dde-9b41-8065-0b3cf0923197 to https://az-eastus-1.cognitedata.com/api/v1/projects/ra-istc-sandbox/assets/byids failed with status 403: Resource not found. This may also be due to insufficient access rights..
The permissions on the dataset for my user group is
raw:readraw:writeraw:listdatamodels:readdatamodels:writedatamodelinstances:readdatamodelinstances:writedatasets:readdatasets:writedatasets:ownertimeseries:readtimeseries:writefiles:readfiles:writeevents:readevents:writesequences:readsequences:write3d:read3d:create3d:update3d:deletetransformations:readtransformations:writefunctions:readfunctions:writeextractionpipelines:readextractionpipelines:writeextractionruns:readextractionruns:writeextractionconfigs:readextractionconfigs:writeentitymatching:readentitymatching:writeannotations:writeannotations:readannotations:suggestannotations:reviewsessions:listsessions:createprojects:listprojects:readgroups:list
Any ideas are appreciated.
Chris
