Concurrent API calls with multithreading. I don't get the same result as from one large call
  • October 31, 2024
  • 52 views
Anders Brakestad
Hi Developers! :)
I have a use case where I need to retrieve a large number of Time Series data points from CDF. We are a final DataFrame with a shape of approximately (1000, 400000).  So a total of 4 billion data points + the index. I also want the data retrieve to be fast…. :)
So instead of retrieving everything in a single call to `client.time_series.data.retrieve_dataframe`, I thought to use multithreading to start the retrieves in an approximately parallel fashion, and then concatenate the resulting dataframaes at huge runtime gains! However, I observe that the results from multithreading do not equal the results from the single call. :(
Specifically:
I split the data retrieval on Time Series IDs, and concatenate along axis=1. I observe that data from the “first two” threads have a lot of missing data, while data from the last two threads are 100% correct. I have also tried to split the DatetimeIndex and multithread along this dimension, but I see exactly the same result in that some of the “splits” show correct data some do not.
Here is a working example (although a bit reduced in data size) that produces the observed discrepancies:
# Setup
import pandas as pd
import numpy as np
from multiprocess.pool import ThreadPool
client = CogniteClient()
ids = [151613618059, 1084354269001, 4066648994349, 4278941460069, 4709909452530, 5042390272421, 6066084198436, 8037054137423, 9102266532608, 10454740690987, 11198241701932, 11442771394712, 11924255376671, 12205298840213, 12450015417880, 13102387455282, 13867954881929, 14302640993401, 15260857832022, 16362008262827, 17197578322170, 17418680798200, 17647258485390, 18690562773274, 22110867945088, 22604477330101, 22803842097478, 24743043888447, 28003968041505, 28705019938259, 32124743715415, 32174031561617, 32628253858149, 32800502091827, 33092491779293]
retrieve_kws = {
    "id": ids,
    "granularity": "1min",
    "aggregates": ["average"],
    "limit": None,
    "uniform_index": True,
    "include_aggregate_name": False,
    "column_names": "id",
# Define retrieve functions
def split_date_range(dr: pd.DatetimeIndex, n: int) -> list:
    """Split a date range into n subsets.
    End exclusive in each split.
    Args:
        dr (pd.DatetimeIndex): Date range
        n (int): Number of subsets
    Returns:
        list: List of tuples with start and end times
    splits = np.array_split(dr, n)
    result = []
    for split in splits:
        result.append((split[0], split[-1] + pd.Timedelta(dr.freq)))
    return result
def retrieve_single(client: CogniteClient, start: pd.Timestamp, end: pd.Timestamp, kwargs) -> pd.DataFrame:
    """Retrieve time series data in a single call to the API.
    Args:
        client (CogniteClient): Cognite client
        start (pd.Timestamp): Start time
        end (pd.Timestamp): End time
        kwargs (dict): Keyword arguments for the retrieve method
    Returns:
        pd.DataFrame: DataFrame with time series data
    return client.time_series.data.retrieve_dataframe(
        start=start,
        end=end,
        **kwargs,
def retrieve_concurrent(client: CogniteClient, start: pd.Timestamp, end: pd.Timestamp, kwargs) -> pd.DataFrame:
    """Retrieve time series data concurrently with multiple threads.
    Args:
    Returns:
    dr = pd.date_range(start, end, freq=kwargs["granularity"], inclusive="left")
    splits = split_date_range(dr, 4)
    args = [(client, start, end, kwargs) for start, end in splits]
    with ThreadPool(4) as pool:
        results = pool.starmap(
            retrieve_single, args
    return pd.concat(results, axis=0)
# Retrieve data
end = pd.Timestamp.now().floor("1d")
start = end - pd.Timedelta(weeks=30)
df1 = retrieve_single(client=client, start=start, end=end, kwargs=retrieve_kws)
df2 = retrieve_concurrent(client=client, start=start, end=end, kwargs=retrieve_kws)
Sample output:
# Data from normal retrieval
                     151613618059  1084354269001  4066648994349  4278941460069  4709909452530
2024-04-04 00:00:00           NaN      75.687863            0.0       0.609659            NaN
2024-04-04 00:01:00           NaN      75.675496            0.0       0.625718            NaN
2024-04-04 00:02:00           NaN      75.667475            0.0       0.587738            NaN
2024-04-04 00:03:00           NaN      75.693901            0.0       0.615769            NaN
2024-04-04 00:04:00           NaN      75.681177            0.0       0.622529            NaN
2024-10-30 23:55:00           NaN      77.970664            0.0       0.000000            NaN
2024-10-30 23:56:00           NaN      78.110861            0.0       0.000000            NaN
2024-10-30 23:57:00           NaN      78.313353            0.0       0.000000            NaN
2024-10-30 23:58:00           NaN      78.445857            0.0       0.000000            NaN
2024-10-30 23:59:00           NaN      78.362344            0.0       0.000000            NaN
[302400 rows x 5 columns]
# Data from multithreaded retrieval
2024-10-30 23:55:00           NaN            NaN            NaN            NaN            NaN
2024-10-30 23:56:00           NaN            NaN            NaN            NaN            NaN
2024-10-30 23:57:00           NaN            NaN            NaN            NaN            NaN
2024-10-30 23:58:00           NaN            NaN            NaN            NaN            NaN
2024-10-30 23:59:00           NaN            NaN            NaN            NaN            NaN
Another thing I observe is that if I reduce the amounts of data to be retrieved (by limiting the number of time series or the date range), I get 100% match between the normal and multithreaded method.
I can already anticipate the reply: “We do not recommend retrieving data from the API in this manner.” :P If so, what would be the best practice for speeding up large data retrieval?
Thanks for the help!
Anders
Best answer by Håkon V. Treider
Short answer as to why retrieve_concurrent is no faster, is that the CogniteClient uses a singleton thread pool executor (TPE), and each of these tasks probably saturate it on its own - or - on the off chance they are not, the API is probably 429’ing you and telling you to slow down.
There’s ~three/four approaches here given that you really need to speed up this retrieval process:
  1. A lot of time is spent combining numpy arrays into the final dataframe. Use retrieve_arrays instead and write your own concatenator logic (the SDK simply uses pd.concat).
    1. If you don’t need all time series in the final dataframe, you can save a ton of time concatenating smaller subsets.
  2. Patch the SDK and replace the singleton TPE with “a new TPE on each method call invocation” so that your 4 threads each calls into a pool of their own.
    1. This will probably lead to excessive 429 (as you are basically DOSing the API). To solve this, each client should be a separately instantiated principal with its own request budget towards the API.
  3. Don’t split the time domain, but split on the number of time series.
  4. Play around with max_workers . Note that due to the nature of the singleton TPE, after the first function call, the size won’t change so you need to restart e.g. your notebook to test with a different value.
And lastly, we do not recommend retrieving data from the API in this manner 😉
  • Backend developer
  • 36 replies
  • October 31, 2024
I’m not an expert in the Python SDK, but in general, if you want to retrieve time series in parallel, I would let the SDK deal with time ranges and paging, and only do parallelization across time series. That should also be the fastest.
Edit: Too slow, and Håkon had a better answer anyway :)
Anders Brakestad
Thanks for the insights!
It looks like the effort to make multithreading work is not worth it. I might play around with retrieving numpy arrays, but I’ll probably settle for a bit of wait time.
