Is it possible to host a pickle file (which contains a ML model) in CDF and use it to make predictions for the available data in the platform?
If yes, what are the steps ? I browsed the documentation but I haven’t found anything relevant
Best answer by JonHaslanger
A pickle file can be uploaded to CDF as a standard “file” type of data. Then you can call the file via the API from your python code as a bytestream using the client.files.download_bytes(id=<fileID>)
Regards
-Jon
Already have an account? Login
