CDF Transformations filter at dataset level
Is there a way to query metadata of TimeSeries from a particular dataset in CDF Transformations?
Something like this, but this query isn’t working
select
  cast(`externalId` as STRING) as externalId,
  cast(`dataSetId` as STRING) as eid
from
  `_cdf`.`timeseries`
where dataSetId == <data_set_id>;
Best answer by Jatin Sablok
Yes it did. THanks
Everton Colling
  • 163 replies
  • April 25, 2024
Hi Jatin,
The query you shared works fine. I just tested it on my side, both in the Fusion UI and using the API, as below:
Can you confirm if you passing the dataSetId as an integer?
I agree with @Everton Colling , also tested on my side in the UI
with both
where dataSetId == 638923115923336 OR
where dataSetId == ‘638923115923336’
It returns everything as expected.
What message do you get?
If you are looking to see the metadata of the timeseries, you can add “select metadata as metadata” to your query
  • 34 replies
  • April 25, 2024
Thanks. I think I was using dataset name instead of ID. But thanks once again !!!
  • 285 replies
  • April 25, 2024
@Jatin Sablok , There’s a builtin CDF function for this:
https://docs.cognite.com/cdf/integration/guides/transformation/write_sql_queries#dataset_id
you use the external_id and it will resolve the id for you.  Scales across cdf dev/stage/prod projects this way:)
Jason
Hi @Jatin Sablok,
Has the information provided helped address your concerns?
  • 34 replies
  • May 31, 2024
Yes it did. THanks
