I would like to know if there are timeout restrictions for functions, as I've been executing a function that reads data from a RAWs table in batches, and since there are many records (1M), it takes up to 10 minutes and I get a timeout error. Is there a way to configure this restriction? Running the same function code on a local machine takes around 2 or 3 hours.
I’d like to understand your workflow intent for using Cognite Functions. I’d be happy to help with solutioning. Could you leverage CDF transformations? Transformations can read from CDF Raw and write to many targets: CDF Staging (Raw), CDF Resource Types and Data Models. Could you partition your use case?
