Transformations to Sequences
I have a daily feed data of the form coming as a file in sharepoint
Date AX1 AB1 AW1 AN1 AR1 AB1 BW1 BG1 BT1
01-01-2023 0.23 1.23 2.54 0.98 0.655 1.09 0.87 0.34 0.19
01-02-2023 0.34 0.56 0.44 0.89 0.576 0.81 1.29 1.11 0.67
I need to pull this data and transform it into an applicable resource-type (Sequences in CDF). I don’t want to store as time series since I need this in tabular form to operate further and do matrix and dot product etc.
Is there a way to write a transformation to push it as ‘sequences’ so that I can use it as a matrix to perform further calculations?
Please share some example SQL transformation snippets to achieve this.
Best answer by roman.chesnokov
Hey @eashwar11 , I’m not sure if the sequence data type fits your needs. Do you have any reasons for using that particular type? I would recommend using time series. instead. You can easily access the values as tabular data (pandas DataFrame).
client.time_series.data.retrieve_dataframe(list_of_external_ids, start='1m-ago', end='now', aggregates=['average'], granularity='1d')
But if you don’t need to visualise the data, you can do the same directly from the RAW.
client.raw.rows.retrieve_dataframe(db_name, table_name, limit=-1)
roman.chesnokov
  • 56 replies
  • July 17, 2023
  • 223 replies
  • July 26, 2023
Hi @eashwar11, did the above help you?
  • 42 replies
  • July 27, 2023
Hi @Carin Meems
It did help!, Thanks for the inputs.
