Issue in calling FDM Post APIs
  • February 21, 2023
  • 7 replies
  • 124 views
I am trying new FDM APIs. In POST endpoints I am facing issue “Missing body for POST request”
Am I missing some parameters? I am using POST body as per documentation
Best answer by Snehal Jagtap
@Juan Alvarado yeah it was postman setting issue, not sure in headers postman is giving as data-raw and by changing it to data it worked. Thanks!
Hi @Snehal Jagtap, and thanks for reaching out.
It would be very helpful if you included the request payload you’re trying to use, resulting in the problem you’re experiencing?
  • February 21, 2023
This is the payload I am trying to use in POST Space API
https://westeurope-1.cognitedata.com/api/v1/projects/slb-pdf/models/spaces
"items": [
"space": "snehal-test-space",
"description": "snehal-test-space",
"name": "snehal-test-space"
Headers :
--header 'content-type: application/json' \
--header 'cdf-version: alpha' \
--header 'Authorization: Bearer <token>’
Forum|alt.badge.img+4
Hi @Snehal Jagtap
I'm quite new around here so I could be 3 steps behind you.  But is that the correct url for applying spaces?  Should "models" be replaced with "datamodelstorage" as below?
api/v1/projects/{project}/datamodelstorage/spaces
Docs
  • February 21, 2023
I tried with this as well, still I am getting same issue. Am I missing something in request?
It looks like the external id field is required in the request.
Juan Alvarado
@Snehal Jagtap the error “missing POST body” suggests the request is malformed. Have you tried different tools (Postman, curl, VSCode REST client, etc.)?
  • February 21, 2023
