is there a distinct filter for Data modeling sdk instance query method
I'm using python sdk and wanted to query instances based on a condition using “data_modeling.instances.query” method. i have a view “TimeseriesProperty” and it has a direct relation/reference to "TimeseriesPropertyType" view. Is it possible to have a distinct filter on the result, because multiple “TimeseriesProperty” instances can have the same "TimeseriesPropertyType"  instances , we don't want duplicated "TimeseriesPropertyType"  instances coming in response for below query:
view_id= ViewId(space="slb-pdm-dm-governed", external_id="TimeseriesProperty",version="2_0")
v_id_2_PROP = ViewId(space="slb-pdm-dm-governed", external_id="TimeseriesPropertyType",version="2_0")
query= Query(
    with_=
                "TimeseriesProperty":NodeResultSetExpression(
                        limit=10,
                        filter= HasData(views=[view_id])),
                "TimeseriesPropertyType":NodeResultSetExpression(
                limit=10000,
                direction="outwards",
                from_ = "TimeseriesProperty",
                through = view_id.as_property_ref("propertyType"),
                filter= HasData(views=[v_id_2_PROP]))
    select={
        "TimeseriesProperty": Select([SourceSelector(view_id, properties=['propertyType'])]),
result = client.data_modeling.instances.query(query)
Best answer by Anders Albert
Thanks for the clarification. I think the the following should do the trick.
query= Query(
    with_=
                        limit=10,
                        limit=10000,
    select={
        "TimeseriesPropertyType": Select([SourceSelector(view_id, properties=['*'])]),
Note the difference between this an the original query is the select part. You select ‘TimeseriesPropertyType’, which will return only the unique TimeSeriesPropertyTypes regardless if it is linked to multiple timeseries properties.
Anders  Albert
  • 121 replies
  • April 3, 2025
No, we do not have a distinct filter. But I might be missing something here, but can’t this be solved with aggregation? Something like
from cognite.client.data_classes.aggregations import Count
client.data_modeling.instances.aggregate(view_id, Count("propertyType"), limit=10)
  • 24 replies
  • April 4, 2025
Hi ​@Anders Albert !
Thank you for the response. This gives the count of "TimeseriesPropertyType" instances that are attached to "TimeseriesProperty" view, which has a lot of duplicates. we only what unique values of "TimeseriesPropertyType" instances that are attached to "TimeseriesProperty" view. is there any way to achieve that?
Anders  Albert
  • 121 replies
  • April 4, 2025
query= Query(
    with_=
                        limit=10,
                        limit=10000,
    select={
  • 24 replies
  • April 6, 2025
Thank you!
  • 24 replies
  • April 7, 2025
hi ​@Anders Albert !
This gives the unique TimeSeriesPropertyTypes with its externalId and space, but this doesn’t give all fields from ‘TimeSeriesPropertyTypes’  view, just its space and externalId. do i need to extend this query?
  • 24 replies
  • April 14, 2025
the ‘TimeSeriesPropertyType’ view also has additional direct reference to 9 other views. so if i want to fetch say external Id of these 9 fields,  i would need to extend the query for all 9 views like i did for dimension?:
type TimeSeriesPropertyType
description: String!
 dimension: PropertyDimension
 # like that 8 other view reference
        query= Query(
        with_=
                                limit=10,
                                filter= HasData(views=[view_id_ts])),
                                limit=10000, #resolve cursor!
                                through = view_id_ts.as_property_ref("propertyType"),
                                filter= HasData(views=[view_TS_PROP_TYPE])),
                        "dimension":NodeResultSetExpression(
                                from_ = "TimeseriesPropertyType",
                                through = view_TS_PROP_TYPE.as_property_ref("dimension"),
                                filter= HasData(views=[ViewId(space="slb-pdm-dm-governed", external_id="PropertyDimension",version="1_0")]))
        select={
                "TimeseriesPropertyType": Select([SourceSelector(view_id_ts, properties= [ "*" ])]),
                "TimeseriesProperty": Select([SourceSelector(view_id_ts, properties=["*"])]),
                "dimension": Select([SourceSelector(ViewId(space="slb-pdm-dm-governed", external_id="PropertyDimension",version="1_0"), properties= [ "*" ])]),
        cursors= {"TimeseriesProperty": nextcursor}
  • 24 replies
  • April 15, 2025
able to get the details that i need if i change the view_id in select statement:
select={ "TimeseriesPropertyType": Select([SourceSelector(view_TS_PROP_TYPE, properties=['*'])]), })
going ahead and closing this.
