This guide describes how to run the Cognite dB Extractor in a separate Docker container to fetch data from Postgres server to Cognite Data Fusion.
Prerequisites
Running instance of PostgreSQL server and valid credentials to SELECT rows from the table in question
Docker host that can access the PostgreSQL server
Running CDF project with an Azure AD service principal with capabilities to write either to CDF.
1 - Prepare Docker Image
Cognite provides the database extractor as a Docker image published to Docker Hub, requiring just the addition of an ODBC driver. Since we are connecting to PostgreSQL we will install drivers provided by PostgreSQL for Debian 11, using this Dockerfile:
Note! Go to https://hub.docker.com/r/cognite/db-extractor-base/tags to see the latest version of the Docker image
FROM cognite/db-extractor-base:2.5.0-beta5
RUN apt-get install odbc-postgresql
Build the image:
docker build -t cognite-db-postgres .
2 - Setup extractor config
The extractor will read a local configuration file that as a minimum defines named config.yml
Details for authenticating towards CDF
Database configurations
SQL query
Authentication towards CDF
This section of the config file declares details required for the extractor to authenticate to be able to write to CDF. To create a new app registry in Azure AD please refer to the relevant section at docs.cognite.com.
cognite:
host: https://api.cognitedata.com
project: lervik-industries
idp-authentication:
client-id:
client-secret:
token-url: https://login.microsoftonline.com/[tenant]/oauth2/v2.0/token
Scopes:
- "https://api.cognitedata.com/.default"
cognite.project | Unique name of the CDF project - displayed in Cognite Data Fusion upper left corner |
cognite.host | The domain name where the api for resides. Example https://api.cognitedata.com and https://westeurope-1.cognitedata.com |
Cognite.idp-authentication.client-id Cognite.idp-authentication.client-secret | Azure AD Application ID for a valid app registration and associated secret. Details available in docs.cognite.com. |
Cognite.idp-authentication.token-url | The token URL for the Azure AD tenant used, usually https://login.microsoftonline.com/[tenant]/oauth2/v2.0/token |
cognite.Scopes | OIDC Scope required to access the CDF API. <cognite.host>/.default, for example https://api.cognitedata.com/.default |
Database connections
This section declares one or more databases the extractor will connect to. Since the configuration supports more than one, it is a yaml list.
databases:
- name: postgres
connection-string: "driver={PostgreSQL UNICODE};SERVER=192.168.1.14;DATABASE=testdb;PORT=5432;UID=sa;PWD=**"
name | Local label used to reference database connections in the query (next section) |
connection-string | Connection string declaring which driver to use and required details to connect. Each key-value is separated by ; |
SQL query
The queries section declares the SQL query the extractor will run, against which one of the databases declared in the previous section and the CDF destination the result set will be written to.
queries:
database: postgres
query: >
SELECT * FROM phonebook;
destination:
database: "CDF_RAW_DB"
table: "CDF_RAW_TABLE"
primary-key: "phone"
queries.name | Freely selected name of the query, used by the extractor when logging |
queries.database | The database connection to be used - the name of one of the connections declared in previous section |
queries.query | SQL query to be executed - result set column names to be exactly like the source table when writing to CDF Raw. Use sql alias as source columns does typically not have these names. |
queries.destination-type | The destination within CDF the extractor will write the result set to. |
3 - Running the extractor
First we create a docker compose file named docker-compose.yml
that will terminate the process once the extraction is completed. (There are other possible approaches, e.g. link):
version: '3'
services:
db-extractor:
image: cognite-db-postgres
volumes:
- ./config.yaml:/config.yaml
network_mode: host
command: /config.yaml
Then, to run this file we simply do:
docker-compose up
The container log will look something like this:
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:14.946 UTC [INFO ] MainThread - Starting extraction of 1 queries
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.101 UTC [WARNING ] QueryExecutor_0 - Could not set timeout on the ODBC driver - timeouts might not work properly.
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.101 UTC [INFO ] QueryExecutor_0 - Connected to postgres successfully
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.102 UTC [INFO ] QueryExecutor_0 - Starting extraction of phonebooks
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.181 UTC [INFO ] QueryExecutor_0 - No more rows for phonebooks. 3 rows extracted in 0.0789 seconds
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.303 UTC [INFO ] QueryExecutor_0 - Uploaded 3 raw rows
db-extractor-postgres-db-extractor-1 | 2022-12-04 09:57:15.303 UTC [INFO ] QueryExecutor_0 - Closing ODBC connection to postgres for phonebooks
db-extractor-postgres-db-extractor-1 exited with code 0
The extractor has now uploaded raw data to CDF.
4 - Complete example config.yml
# Read all of these from environment variables
cognite:
host: https://bluefield.cognitedata.com
project: pedro
idp-authentication:
client-id: "**"
secret: "**"
token-url: https://login.microsoftonline.com/**/oauth2/v2.0/token
scopes:
- https://bluefield.cognitedata.com/.default
# Type of configuration
type: local
# Logger Settings
logger:
console:
level: INFO
# State storage
extractor:
state-store:
raw:
database: "goals"
table: "phonebook"
upload-interval: 30
# List of databases
databases:
connection-string: "Driver={PostgreSQL UNICODE};Server=127.0.0.1;Port=5432;Database=postgres;Uid=postgres;Pwd=mysecretpassword;"
# List of queries
queries:
database: postgres
query: >
destination:
database: "goals"
table: "phonebook"
