Alerts not being triggered in charts
Forum|alt.badge.img+4
Hi. I’m trying to understand why no alert has been triggered for the following monitoring job.
Am I right to understand that this monitoring job should trigger an alert when the time series is above the specified threshold? (I am a bit confused by the text “alert when the threshold is”. Is this perhaps not monitoring the time series itself, but a threshold specified on the threshold tab?)
Best answer by Kristian Nymoen
It works now.
I was missing capabilities for sessions:list, sessions:create, sessions:delete
Thanks!
Arun Arunachalam
Hei thanks again for your feedback on this ! Yes it should alert in that situation. Basically that parameter is just the threshold value and the backend checks if an alert lasts for atleast one minute and then sends out an alert. I will ask the team to look into this on the backend side to make sure things are in order. Do you have the correct CDF groups setup ?
Thanks. Groups setup, as in capabilities, or something else?
I’ve got the dataPipelinesApiExperiment, monitoringTaskApiExperiment, alertsApiExperiment capabilities set for my user.
It works now.
Thanks!
Arun Arunachalam
Fantastic glad to have got this working for you ! 😁
