Push multiple timeseries in CDF with DB extractor
Forum|alt.badge.img+6
Hello! Is there a way to push multiple timeseries in CDF timeseries within one single query in the DB extractor config.yml file? Or do we need multiple queries?
Also, if my incremental field is a timestamp datetime format, is it working or not as I'm receving an error related to it.
Raluca
Hi @Raluca Bala,
I hope now you are able to execute multiple queries after adding "-" to the config file as per the below example.
queries:
    -   name: my_name_1
        database: my_database
        query: first_query
    -   name: my_name_2
        query: second_query
As of now, I will be closing this thread. If you have any questions please feel free to create a post in hub
Hi @Raluca Bala,
Just a quick reminder to take a look at our documentation. To help you with the issue, could you please share the following details?
- Extractor version
- Error message
- Configuration file
Hi @Dilini Fernando , thanks for replying to to this. I’ve gone through the documentation. I’ve managed to create a query to account for multiple timeseries at once and used this conversion within the query for the incremental field chosen as datetime (timestamp):  CAST({incremental-field} AS DATETIME2) >= '{start-at}' . Otherwise it cannot compare the timestamp with a state stored value as string.
Raluca
@Dilini Fernando , I have another question/issue: I haven't figure it out how can I retrieve also string/text columns in a separate query with the DB extractor. Tried to put them separately in 2 queries, one for numeric/float columns and one for string/text column but the extractor apparently runs only the second/last query listed in the config.yml file. I also managed to extract all numeric and string/text columns in one query but they are pushed in CDF timeseries as string types.
Hi @Raluca Bala,
I've created a support ticket for this, and the team will investigate and provide you with an update.
Hi @Raluca Bala,
queries:
    -   name: my_name_1
        query: first_query
    -   name: my_name_2
        query: second_query
Thank you, @Dilini Fernando , I've managed to solve it with the above solution from Cognite support team.
