CDF Toolkit Instances deployment using csv file
  • February 6, 2025
  • 9 replies
  • 97 views
Ayush Daruka
Can we use a CSV file instead of a Yaml file containing details of the instances we want to populate in a view using CDF toolkit? If yes, is there a limit to it?
Edit:  What I mean to ask is whether we can use a csv file directly to populate a view in a data model, i.e. without using raw and transformations? Just like we can use a node.yaml file to directly deploy an instance in a view.
Best answer by Anders Albert
 ​@Ayush Daruka We have release Toolkit `v0.4.7` which has alpha support for populating nodes through a view from a csv or parquet file.
You enable it in the `cdf.toml` with the following
[alpha_flags]
populate=true
The command is `cdf populate view`.
Ayush Daruka
  • 25 replies
  • February 6, 2025
Forum|alt.badge.img+4
We have some of our instance data in csv files, and it works well. Our files are structured like this;
key name description aliases source ...
external id 1 name 1 ... ... ... ...
external id 2 name 2 ... ... ... ...
The files are deployed to raw via cognite toolkit and then instances are populated with transformations/workflows.
None of our CSV-files are very large though. I think the largest ones are approximately 300 rows.
Ayush Daruka
  • 25 replies
  • February 6, 2025
Thanks for the information. Have you also tried using the csv directly to populate a view just like we can with a node.yaml file?
No, our node.yaml files only contain node types, no instances.
Anders  Albert
  • 111 replies
  • February 11, 2025
@Ayush Daruka as ​@Kristian Nymoen is saying only a YAML file is supported and it is intended for either node types or configuration nodes. For populating large amount of nodes transformations/or custom script/an extractor are the only options.
Note I have logged this as a feature request for Toolkit.
Ayush Daruka
  • 25 replies
  • February 11, 2025
@Anders Albert Thanks for confirming!!!
Anders  Albert
  • 111 replies
  • February 13, 2025
[alpha_flags]
populate=true
Ayush Daruka
  • 25 replies
  • February 13, 2025
@Anders Albert Thanks for sharing this. Let me try it out and get back if I have any questions.
Ayush Daruka
  • 25 replies
  • February 13, 2025
[alpha_flags]
populate=true
@Snehal-Jagtap ​@Neerajkumar Bhatewara
