Implemented
Selecting a data model in transformations improvement
Related products:Transformations and RAW
  • April 19, 2024
  • 9 replies
  • 193 views
The current selection of the target data model when creating in a transformation is sort of a lazy load:
Only these three data models are available when dropping down. There are dozens of data models in the project
However, as the project grows, the loading of the data models can take too long, since it’s very possible to exist dozens of data models, and it loads the data models one by one. Also if you close the pop up it will start over.
I suspect this is because it’s fetching all the information about the data models - all versions and views available - to fill the other options in other fields. And that could be too much to load all at once.
The proposal is to fetch all data models at once, but only their names. And then once the data model is selected, fetch the rest of the information from that data model only.
This way we can have a more responsive UI when selecting these and reducing the amount of unecessary data we are fetching.
Andreea Oprea
  • 136 replies
  • April 22, 2024
Hi @Marcos Falcão y Martin,
We have received your request. Our PM, @Elka Sierra,  will review your proposal and come back to you.
Thank you,
Andreea.
Jørgen Lund
  • Product Manager
  • 113 replies
  • May 14, 2024
Hi @Marcos Falcão y Martin, thanks for this great feedback!
Just to confirm: you are currently experiencing slowness/bad performance in the project you’re working in?
We’ll look into improving how the list of models is loaded.
We’re also considering improvements to the target selection flow for Transformations in general. If you happen to have more feedback, feel free to leave it here - all input is appreciated!
Hello @Jørgen Lund, hope you are doing well
Yes, this is a reccurring issue in all the projects I had to create a transformation for - I believe it’s an issue in the API call itself when the project has too many data models already
Jørgen Lund
  • Product Manager
  • 113 replies
  • February 6, 2025
Hi ​@Marcos Falcão y Martin, apologies for taking some time to get back to you - could you check and see if you still experience the slow loading issue? We’ve made some changes and are not able to reproduce it on our side anymore, so just wanted to confirm if you’re seeing the same improvement
Hello ​@Jørgen Lund! No worries.
I’m not experiencing the lazy loading anymore i.e., all the data models load at once.
However, we now have a big initial loading that takes something like 2 minutes or more to run (celanese-dev project)
I’ve noticed in the console it does multiple calls to the “tables” endpoint - I think one for each data model in the project.
Jørgen Lund
  • Product Manager
  • 113 replies
  • February 13, 2025
Hi ​@Marcos Falcão y Martin, thanks for the update. Could you provide some more context on what you describe above? When are you seeing 2 minute loading windows? Is it in the Transformations UI?
Hey ​@Jørgen Lund! Correct, this is the transformation UI, when selecting the target data model.
Jørgen Lund
  • Product Manager
  • 113 replies
  • February 26, 2025
@Marcos Falcão y Martin - I’m not able to reproduce this, I see no calls to /tables. Could you share a full screenshot (or a few screenshots) for where in the UI flow you’re seeing these calls and slow loading so I’m sure we’re looking into the right areas?
@Jørgen Lund
No data model option available to select
Multiple calls to tables endpoint. While these calls are not finished, the data models don’t load
