Python SDK using poetry
  • March 2, 2023
  • 5 replies
  • 170 views
I have cloned the following in my local DEV folder.
using-cognite-python-sdk.git
I have also installed the dependencies that are defined in the pyproject.toml in the repo.
To run the code in jupyter notebooks. (Note: Change the "Kernel" to use the virtual environment created by poetry.) and add new libraries as needed.
How do I change the Kernel in jupyter notebook to the one created by poetry? When I open the jupyter notebook from the repo folder, it shows the general python3 (ipykernel) but this was present even before I installed poetry.
So how do I change the kernel in my notebook.
Please advise.
Best answer by Kristian Gjestad Vangsnes
Thank you @eashwar11! Can you try to add ipykernel by running
poetry add ipykernel
and then run ‘poetry run python -m ipykernel install --user --name myname’ again?
Hi @eashwar11, if you have installed poetry and ran `poetry install`, have you activated the environment? if so, can you try installing the ipykernel directly : poetry run python -m ipykernel install --user --name myname ?
  • March 3, 2023
Thanks @Kristian Gjestad Vangsnes . I can see the environment is activated (as shown below in BLUE). But when i try to install ipykernel directly, it is giving the following messages (highlighted in yellow). I am trying to clone the extractor-utils repo and work to create a custom extractor in my local.
D:\pycdf\python-extractor-utils-master\python-extractor-utils-master>poetry env list
cognite-extractor-utils-yeiQVxSK-py3.9 (Activated)
D:\pycdf\python-extractor-utils-master\python-extractor-utils-master>poetry run python -m ipykernel install --user --name eashwar_n
C:\Users\eashwar_n\AppData\Local\pypoetry\Cache\virtualenvs\cognite-extractor-utils-yeiQVxSK-py3.9\Scripts\python.exe: No module named ipykernel
  • March 3, 2023
Great! It worked now. I added the ipykernel and then ran the above command. After launching the jupyter notebook, I could see the new env with <myname> showing up in the notebook.
Thanks a lot!
No problem @eashwar11, thank you for reaching out! We will make sure that the documentation is updated.
