Gathering Interest
Transformations: Asset External IDs instead of IDs for linking Events, Timeseries, Sequences to Assets
Related products:Transformations and RAW
Pierre  Pernot
That would be nice to be able to use the asset external IDs (instead of the assetId field) in transformations, to link events (or timeseries, sequences) to existing assets.
+1
or at least to extend the function
https://docs.cognite.com/cdf/integration/guides/transformation/write_sql_queries/#asset_ids
to be able to use externalId as well
Using names can lead to unexpected results since they are not unique
In general, we would also like to be able to create our own custom SQL function as well
FWIW, the reason we link by internal ID of the asset has to do with fact that we allow externalIds to be mutable in the current asset centric model.
That might not (shouldn’t) prevent a transformation from looking up on the externalId of the asset, and use it’s assetId (the internal ID) to create a link.
thanks @Thomas Sjølshagen , yes that makes sense.
Yes as a data engineer, you will most likely know the external_id so having a way to find the id from external_id is necessary. It would be good to have either a custom function for that or allowed directly in transformations
  • 590 replies
  • March 3, 2023
NewGathering Interest
Hello
Any new development on this?
