How to run the OPC UA extractor with Docker [Cognite Official]
  • October 26, 2022
  • 5 replies
  • 543 views
Pierre  Pernot
OPC UA is an open source data standard for communication. It is one of the most used in the industry. OPC UA can for example be used to send data from a machine and its sensors to a computer (or to a cloud service such as Cognite Data Fusion).
In this article, we’ll see how to extract data from an OPC UA data source to Cognite Data Fusion (CDF). For this purpose, we have an off-the-shelf extractor that we simply need to configure and deploy. This extractor is maintained by Cognite. You can find it in CDF under Integrate > Extract data (where you can also find our other extractors: DB, PI etc., you can also create custom extractors).
gWXmmkcdd0VcmTTCg-0eKb7G15G5QYKT4T5zMhUm7wu0lXy7dC8UdBiPWFnvAkW3PWB4LCfgiF-96UBApWTtx3CS6OYPxZVmPf3eakduCsPwPnc_GwVqPkrOudVAUmTmBRljO7aN-_tBBuN6EMnlw3zMqJtO8xqm9zXKH0qDWwIE0X4ZyKTjsfd_IQ
One of the most common and easiest ways to deploy such an extractor is via a Docker image. The fact that it is platform agnostic makes it pretty easy to deploy: you just need docker installed to make it run. Also, everything you need is packaged in the image, you do not need to install or build anything. The Docker images are available on Docker Hub (https://hub.docker.com/r/cognite/opcua-extractor-net/tags).
In this article, we’ll take a look at version 2.9.1. This version introduces the ability to edit the config file remotely from CDF. If you prefer not to use this feature, you can still follow along this article: you’ll simply need to have everything in the same config file and delete the “type: remote” parameter, the rest will be the same.
There are many configuration items available with our OPC UA extractor. In this article, we’ll cover only a few of them, since most of them are use-case specific. If you are interested in knowing more about all of the extractor’s capabilities, please check the documentation (https://docs.cognite.com/cdf/integration/guides/extraction/opc_ua/).
If you do not have any OPC UA datasource to use, you can use Prosys OPC UA Simulation Server for training purposes.
The first step consists in creating an extraction pipeline in CDF.
8o0blHHLx3cTh32jRXPCxR-lLtNDNeGMmc4ryyHYRbF1dqM72YMF9JyE7-GG8GkWc5r6iAGtiFVL_KDDOmaRqtkJyGH2xA38hfWYpjmFDSlzAf0oNdK-89nWFH-8lVh8seF4FTXAU25HJ-jlYAYIRo-k1QYh9GGlYUnQ3ew4tscwFGsOnoDgtN3o4A
u_F3VuMQa-1OX3-JdFisdISOLidgqedCAwEpCnLyPl2iJzbkMI5CqrXlLFnzBuO4HFkreH1yRY_-sFCO9bSqsD5wcM9HrIizF77IByM7Uz9RNigL7igQ0pioVJNbmC0nsboHKvP-4UT9qDbZdOmLsAjxCYfZ3tRBxoSXaovx3wcgg0JfmFd8AKIpPw
Fill in the information you need and keep the extraction pipeline’s external ID for the next steps. Once it is created, the second step consists in creating a “config.yml” file in a “config” folder inside of your working directory (the naming convention is important here, it won’t work if you don't respect it).This “config.yml” file will contain all the information related to CDF. It should look like this :
version: 1
type: remote
cognite:
  host: ${BASE_URL}
  project: ${PROJECT}
  idp-authentication:
    tenant: ${TENANT_ID}
    client-id: ${CLIENT_ID}
    secret: ${CLIENT_SECRET}
    token-url: ${TOKEN_URL}
    scopes:
      - ${BASE_URL}/.default
  extraction-pipeline:
    external-id: “<<YOUR_PIPELINE_EXTERNAL_ID>>”
As a comment, config files support variable substitution, you can refer to an environment variable named MY_ENV_VAR with the following syntax: ${MY_ENV_VAR} (as in the code sample above).
At startup, the extractor attempts to read the configuration files from the extraction pipeline with the mentioned external ID. The extractor continues to check for updates every few minutes.
If you are not using the remote configuration (beta feature), the rest of the configuration will also be in the “config.yml” file mentioned above.
Thanks to the remote configuration feature, every configuration item (except the “cognite” information) can be defined in CDF as follows:
StVR7dUTMLzXWGBfi0SKeimKrUol96H0aFSZP5-ZynpIh1rH_vcwOkaI5nYRmRmMVJDloXw3FsjnpojBeLOGlUAlRvFJGzvGtwTVTEQIAefoexCIzeMdTaFE33i4tcRpyECdKXFSRsz8usJMx7Y6OAV1rJbKyFU5BWnsnNDECJW0nZEQ8sWNiorPOA
Inside that remote configuration, enter the following:
version: 1
source:
    endpoint-url: “<<YOUR_OPC_UA_ENDPOINT>>”
This is the very minimal configuration you need to get your extractor running. If you need to authenticate thanks to a user or certificates, please have a look at the documentation.
Now you can run the following command, in your working directory:
docker run cognite/opcua-extractor-net:2.9.1 -v "$(pwd)/config:/config" –rm
Or, if you need certificates:
docker run cognite/opcua-extractor-net:2.9.1 -v "$(pwd)/config:/config" -v "$(pwd)/certificates:/certificates"  –rm
If you run that command, you’ll get data extracted and stored as CDF objects.
The data that is now in CDF is probably not the way you would like it to be. The next step of this article consists in fitting the data to our data model. For this, we will make use of the extraction/transformations parameter (not to be confused with Transformations in CDF) which basically allows you to choose how to model (or to ignore) data based on filters.
The sample data I’m using looks like that:
GbRFVWBDgy4hHeibiVCRdm_7q5rDQgml65pmV23hr9ZF2mnQ2klFPdVCGFmOeqmcjuqiILLIFldfT3gXmSB7KOiDSGoTUiOK1BQfUxNxOouoLwTckal64LMrCM5j7MxWAZUFEiOikIsLs3TLV7-9hvOPQJI0_Ex-gQW8SbJgvyEfAaw6D-U7JK2Q0g
From those nodes, we will keep only the Simulation Object and the Variables under it. The default behavior of the extractor will create an asset for the Simulation object, and timeseries attached to this asset for the Variables. Also, the transformation (type: Property) makes the constant Variable a metadata for the Simulation asset.
First, you’ll have to delete the data you’ve just extracted (to be able to see the changes with the new configuration). Also, stop the running container.
Then, in CDF, in your extraction pipeline configuration, you can edit the configuration itself. Click “Edit”, replace the current config by the one below (adapt to your endpoint URL), and publish the changes. The filter arguments are actually regex that apply here on the display name of the node (check the documentation for all the transformation capabilities). We are also able to select the node that will be the root node (Simulation here) by its node id and its namespace URI (we got those values in UA Expert, which helps a lot for visualizing data). Those values might change in your case, pay attention to put the correct ones.
version: 1
source:
logger:
    # Writes log events at this level to the Console. One of verbose, debug, information, warning, error, fatal.
    # If not present, or if the level is invalid, Console is not used.
    console:
        level: debug
extraction:
    root-node:
        namespace-uri: http://www.prosysopc.com/OPCUA/SimulationNodes/
        node-id: 85/0:Simulation
    transformations:
      - type: Property
        filter:
(in production, you might set the logger console level to something else than debug)
Now run again your docker command :
The extractor will now feed data again inside of CDF, in the wanted format.
The Cognite OPC UA Extractor has many configuration settings available, I strongly recommend to have a look at the documentation: https://docs.cognite.com/cdf/integration/guides/extraction/opc_ua/opc_ua_configuration
If you have any questions or remarks about the extractor and its capabilities, feel free to ask :)
@Einar Omang  is doing a great job developing and maintaining the extractor. @Einar Omang : any best practices you would like to share ?
  • 75 replies
  • October 26, 2022
I have one important tip:
It is highly recommended to run the config tool when setting up against a new type of OPC-UA server. The config tool detects common server issues, generates some useful configuration fields, and debugs the connection for you. Running it is described in the “setup” part of the documentation: found here.
I can also recommend the guide the integration team has created regarding troubleshooting
https://docs.cognite.com/cdf/integration/guides/extraction/opc_ua/opc_ua_troubleshooting
And the OPC UA extractor can also run as a Windows service or as Linux executable if that is your choice of infrastructure. More to come on this soon.
  • July 6, 2023
Thanks for the detailed tutorial.
As of now, I’m unable to see the images in the original post. Not sure if its only me or images have been removed since the publication.
  • Could you review the original post and edit the images so they are visible again?
I’m specially interested in the “Thanks to the remote configuration feature, every configuration item (except the “cognite” information) can be defined in CDF as follows:” image parte, as the online docs show the Github Actions flow but not as detailed the CDF-based flow.
Thanks!
Andre Alves
Forum|alt.badge.img+13
Thanks for the tutorial.
How OPC-UA extract handle reconnection after disconnection in a subscription?
APSHANKAR Sagar
Hello ​@Einar Omang ,
We have been trying to integrate the OPC-UA extractor docker in our operations with a Siemens Industrial Edge IPC 227E (Industrial Linux computer). We have had limited success with it.
The Siemens IPC doesn't allow to execute terminal commands directly. Hence, we have not been able to test the OpcuaExtractor tool to check if our config is ideal.
We managed anyway to deploy the 2.8 version of the docker following the attached guide which we received from Cognite.
The 2.8 version allows us to connect to our OPC UA Server (IIH Semantics) and transmit the data in real-time to CDF including an OPC-UA data model.
However, we want to use more recent versions of the OPC-UA extractor docker, which allow more functionality (like dry runs) and because our current version is now outdated. When we try to install recent versions like the 2.32.0 published recently, we run into the following problem.
The docker fails to access the /certificates/pki/ folder due to a permission issue. This happens ONLY with versions more than 2.8. The volumes permission is the same in our docker compose files.
The docker engine running on the Siemens IPC is version 20.10.
I am attaching the guide we followed,  the logs generated when we use 2.32.0 version and an example of the docker compose file we are using.
Can you guide us on what we may be doing wrong?
Do you have any plans of offering the OPC-UA extractor as an application directly on the Siemens marketplace?
