deploy dry-run with read-only access
  • September 26, 2024
  • 40 views
Forum|alt.badge.img+4
Hi.
We’re administering CDF deployments from Github using github actions and Cognite toolkit.
I’m setting up a github action to automatically perform a dry-run for a pull request to main, and post the dry-run output as a comment on the PR to assist the reviewer.
I’d preferably like to use a client with read-only access to CDF for this, but it seems cdf-tk requires full write access even for dry runs - is that so?
Performing a dry-run locally with read-only credentials results in:
ERROR (AuthorizationError): Don't have correct access rights to deploy iam.groups(all_scoped). Missing:
GroupsAcl(actions=[<GroupsAcl Action.Create: 'CREATE'>], scope=AllScope()) -
GroupsAcl(actions=[<GroupsAcl Action.Delete: 'DELETE'>], scope=AllScope())
Please click here to visit the documentation and ensure that you have setup authentication for the CDF toolkit correctly.
I would expect to see the same error on my github-action, but it stops without much useful information:
Run cdf-tk deploy --env=dev --dry-run > dryrun-output.txt
shell: /usr/bin/bash -e {0}
env:
    PYTHON_VERSION: 3.11
    CDF_CLUSTER: az-***
    CDF_PROJECT: ska***
    IDP_CLIENT_ID: ***
    IDP_CLIENT_SECRET: ***
    IDP_TENANT_ID: ***
    pythonLocation: /opt/hostedtoolcache/Python/3.11.10/x64
    PKG_CONFIG_PATH: /opt/hostedtoolcache/Python/3.11.10/x64/lib/pkgconfig
    Python_ROOT_DIR: /opt/hostedtoolcache/Python/3.11.10/x64
    Python2_ROOT_DIR: /opt/hostedtoolcache/Python/3.11.10/x64
    Python3_ROOT_DIR: /opt/hostedtoolcache/Python/3.11.10/x64
    LD_LIBRARY_PATH: /opt/hostedtoolcache/Python/3.11.10/x64/lib
Error: Process completed with exit code 1.
Best answer by palronning
Hi Kristian, I you’re right: the Toolkit does indeed expect full WRITE/DELETE even for --dry-run, but that shouldn’t be necessary. We should be able to fix this fairly quick. Thanks for reporting!
  • Architect
  • 16 replies
  • September 27, 2024
Hi I am facing same issue with toolkit 0.4.16. Is it not solved yet? Also, please let me know why it needs delete access for deploy?
