SQL query from Cognit Function?
  • May 18, 2022
  • 90 views
Is possible to make a sql query to an external SQL server from a Cognite Function?
Best answer by vwrocks8
@vwrocks8 Is there a known IP that the Cognite Function traffic would be coming from that @Pedersen Jon-Robert  would be able to whitelist on his end so that it’s not completely wide open on the internet?
I am not aware of what infrastructure you are running on. For example, this is how the firewall rules work with Azure SQL:
IP firewall rules - Azure SQL Database and Azure Synapse Analytics | Microsoft Docs
Cognite Functions is primarily designed to operate on data in CDF, and at the moment it’s not possible for us to provide a list or a range of ip addresses that a function can use.
  • Inactive
  • May 18, 2022
Yes, all outgoing traffic is allowed. However your SQL server needs to be publicly available for this to work.
Ben Brandt
  • May 18, 2022
It would be great to know IP adress or IP range that Cognite Functions use.
We are using pyodbc but I could not get that to work with Functions. Any tips or alternatives?
  • Inactive
  • May 19, 2022
