Hi, I want to transform JSON object to Data model column. JSON is populated from extractor to raw table, so its type is by default Object and its structure will be nested.
Is there any built-in/ Custom function using which I can parse this json and convert the specific value into column.
I have tried to_josn () which will convert the json structure to string and then with the help of get_json_object() I can get expected value by passing json path to this function. But problem here is it will always return value as String.
