Transfer Data preview error
  • August 23, 2023
  • 31 views
Sai Ram
Active
Forum|alt.badge.img+4
While performing SQL query preview in Transfer Data getting an error.
Error:
Verify that the 'SaiRam1995.assets' relation exists | code: 400 | X-Request-ID: 5bd0b793-6b30-94c6-986a-f00a8859afae
Best answer by Sofie Haug
Hi @Sai Ram !
I was assuming that you were working on the CDF Fundamentals learning path and using the cdf-fundamentals projects. From what I can see there, it looks like you manage to run your transformations successfully.
I guess you found out, but what most likely happened was that when you created your RAW table in some previous steps, you named it slightly different. There is two options, renaming the RAW table (might have to delete the existing one and create a new), or change the name in the SQL code.
Let me know if you have any other issue ang your journey!
Sofie Haug
Forum|alt.badge.img+7
  • August 24, 2023
Hi @Sai Ram !
