Parallelize restAPI calls with pagination
Hello, I am trying to use “Filter time series” or “List time series” endpoints. However, because of 1000 limit, I need to parallelize these calls as I would like to retrieve thousands of timeseries. The challenge I am facing is the pagination used in these endpoints which is based on id of timeseries. Is there a way to use index as pagination?
Best answer by Jason Dressel
@Diana Chimnaz Johan
client: CogniteClient = ...
print(f"Max Workers: {client.config.max_workers}") #ensure you have workers >1 :)
timeseries = client.time_series.list(limit=None) #not making use of the workers
timeseries = client.time_series.list(partitions=10, limit=None) #will leverage the workers and run in parallel
-Jason
Glen Sykes
  • 123 replies
  • August 16, 2023
Hi Diana, have you tried using the parallel retrieval method, using the /partition parameters?
Read here for more information
Hi Glen, thank you for getting back to me. Can you tell me more about the parallel retrieval method? It sounds like you may have shared a link, but I do not see it.
Glen Sykes
  • 123 replies
  • August 16, 2023
Hi Diane, sorry about that.  Hopefully this link works!
https://developer.cognite.com/dev/concepts/pagination/
  • 285 replies
  • August 18, 2023
-Jason
  • 223 replies
  • August 23, 2023
@Diana Chimnaz Johan did the above help you?
