Python API calls work in Jupyter Notebook, but fail when running as a Python script
Peter Quinn
I have some code working great via a Notebook, but I want to move it to a server where I can run it as daemon. The authentication is failing when I run it on the server.
I suspect the problem is with the Scopes - User impersonation might work in the browser where I’m already logged in to the right project. What scope should I use instead when I’m calling directly from Python?
Also tried
myscope = '[f"https://westeurope-1.cognitedata.com/.default"]'
as suggested in the documentation
oauthlib.oauth2.rfc6749.errors.AccessDeniedError: (access_denied) Unauthorized
from cognite.client import CogniteClient, ClientConfig
from cognite.client.credentials import OAuthClientCredentials
from cognite.client.data_classes import TimeSeries
host = "https://westeurope-1.cognitedata.com"
myproject = "rok-buandcollaborators-53"
clientid = "realStuffWasHere"
secret = "secretsecretsecretsecretsecretsecret"
#myscope = "https://westeurope-1.cognitedata.com/.default"
myscope='["IDENTITY", "user_impersonation"]'
token="https://datamosaix-prod.us.auth0.com/oauth/token"
dataset = 8883655420989208 #chemdemo dataset
#creds = OAuthClientCredentials(token_url=token,client_id=clientid, client_secret=secret, scopes=myscope)
#cnf = ClientConfig(client_name="SJC_Raspi3b", base_url=host, project=myproject, credentials=creds)
        token_url=token, # https://datamosaix-qa.us.auth0.com/oauth/token
        client_id=clientid,
        scopes=["IDENTITY", "user_impersonation"]
cnf = ClientConfig(
    project=myproject,
    credentials=creds,
    base_url=host
cdf_client = CogniteClient(cnf)
ts_list = cdf_client.time_series.list() #debugging test for creds. not needed for real
print (ts_list)
Best answer by Fredrik Holm
Hi Peter.
Here’s a sample script that runs fine on my side, both in a notebook and as a deamon
import os
scopes="user_impersonation"
audience="https://cognitedata.com"
projectName= "holminc-36"
host= "https://westeurope-1.cognitedata.com"
token_url="https://datamosaix-qa.us.auth0.com/oauth/token"
client_id= os.environ["holm_inc_qa_ext_client_id"]
client_secret= os.environ["holm_inc_qa_ext_client_secret"]
oauth_provider = OAuthClientCredentials(
    token_url=token_url,
    client_id=client_id,
    client_secret=client_secret,
    scopes=scopes,
    audience=audience
clientConfig = ClientConfig(
    client_name="Non-prod testing",
    project=projectName,
    credentials=oauth_provider,
    base_url=host,
    debug=False
client = CogniteClient(clientConfig)
print(client.raw.tables.list("Holm Inc db", limit=5))
Please note that this is running in QA and that the scope assigned there are recently changed. The following scope should work in prod now, but needs to change as the scope change in QA is rolled out to prod.
scopes="IDENTITY user_impersonation"
Starting with version 6.6.1 of the SDK, some convenience methods were added to CogniteClient that I suspect might give you an easier way to instantiate a client:
client = CogniteClient.default_oauth_client_credentials(
    project="rok-buandcollaborators-53",
    cdf_cluster="westeurope-1",
    tenant_id="0abcdef...",
    client_id="d9b2bd26...",
    client_secret="...",
    client_name="Who am I?",
# For easy interactive login, check out:
CogniteClient.default_oauth_interactive
Peter Quinn
  • 18 replies
  • August 2, 2023
Thanks. This looks promising How do I find my tenant_id? Does this assume it’s AzureAD? We’re not using that.
  • 9 replies
  • August 3, 2023
Hi Peter.
import os
    scopes=scopes,
    audience=audience
    base_url=host,
    debug=False
Peter Quinn
  • 18 replies
  • August 3, 2023
This is strange. It runs on Jupyter Notebook. It runs on Python on my corp Windows laptop. It fails on the Raspberry Pi that I want to run it on, since that doesn’t get shut off every night. Is there possibly a Windows vs Unix (case sensitivity?) issue?
Anyway, my immediate need has passed so there’s no urgency in solving this mystery
