Domain Expert Fundamentals - Charts - data mismatch in quiz?
  • April 4, 2023
  • 95 views
Johannes
Active
In the Charts chapter, question 7 and 8 in the quiz asks for some reference values that I cannot understand can be correct. The quiz asks for number of  threshold events and durations within a specific timeframe:
From the Data quality use case, how many gaps / events have been detected in Temp in: Gaps detection calculation during the following period: Jun 9, 2022 (9:00) - Jun 10, 2022 (9:00), Type: Between Min & Max of 1?
However, none of the alternatives match the resulting dataset I see in Charts.
I am a new learner, so perhaps a mistake somewhere, but I have checked multiple times and cannot see any error on my part. Is it only me? Or is there a mismatch in the data?
Kind regards
Johannes
Best answer by Sverre Fjerdingstad
Hey @Johannes! I tried this myself just now and got it right (at least something that are alternatives in the quiz🤐). At a glance It does look like you’ve done correct steps... Sometimes you need to refresh/add and remove the threshold filter for it to show the correct values. Either it’s as simple as that or you might wanna try recreating the steps from the Solution video once more.
Sofie Haug
Forum|alt.badge.img+12
  • April 5, 2023
Thank you so much for your feedback! I’ll have to set a side some time to investigate this! I’ll get back to you right after Easter!
Sofie, Cognite Academy
Sverre Fjerdingstad
Johannes
Active
  • April 11, 2023
Hm, must have been a caching issue or something. I opened the same chart on a brand new computer today, and now I see the same results as you. Didn't make any changes, so it must have been solved by the proper refresh.
Thanks for confirming, appreciate the effort :)
