Getting Attribute error in cognite.experimental
  • February 13, 2023
  • 75 views
Hi All,
I am getting error while importing CogniteClient from cognite.experimental.
Please refer the below screenshot of the error.
Best answer by EXT Vivek Subendran
Hi Shubham,
Thank you for sharing the experimental_sdk version it looks like you are using the old version it would be great if you could upgrade to the latest version and try again.
Thank you.
judekumar87
  • February 13, 2023
Hi Shubham,
Without you code it is hard to determine the error. Your complaint is about the below code right?
from cognite.experimental import CogniteClient
Can you kindly share with me the version of the experimental_sdk that you are working with? Also If possible share your code. I hope you have already reffered to our documentation.
Thank you.
  • February 14, 2023
the version our team using for experimental_sdk is 0.74.0
Hi Shubham,
Thank you.
  • February 20, 2023
Hi @Shubham2896, did upgrading your version resolve your issue?
