In Cognite Academy Fundamentals : Working With CDF: Contextualize, I have followed all of the instructions several times for Entity Matching and, in all instances, get “No matches found”, so there is nothing to confirm or write to CDF. What am I missing here?
Cognite Academy Fundamentals : Working With CDF: Contextualize "No matches found"
Best answer by Sofie Haug
Thank you
When we do the Enity matching, we match on the assets name and time series name.
However, I see that you did not successfully update your assets name, mentioned in the steps here: https://learn.cognite.com/path/cognite-data-fusion-fundamentals/working-with-cdf-integrate/865138
All you need to do (explained in the steps in the link above), is to enter the assets transformation and set “name as name” and run the transformation. Then you can go back to the Match entities section!
