We have generated a SDK using pygen on our Model.
Post that we requested a data from particular view in below eg - Property_type. It contains ~138k reocrds
Observe the below results on time taken to fetch via
- Cognite SDK - 44 secs
- Pygen SDK - 82 secs
Its fetching the same data from the same cognite project, but still seeing the performance lag. Its taking almost double time. Both numbers are from my local sandbox.
- Cognite SDK Code
config = {
"client_name": "abcd",
"project": "slb-odf-qa",
"base_url": "https://westeurope-1.cognitedata.com/",
"credentials": {
"client_credentials": {
"client_id": "e063088ad3b4548d4911bd4a617990aa",
"client_secret": "",
"token_url": "https://p4d.csi.cloud.slb-ds.com/v2/token",
"scopes": ["9237c91ce1ea434fa5a91262a5ea3646"],
cognite_client = CogniteClient.load(config)
view_id_1 = ViewId(space="slb-pdm-dm-governed", external_id="PropertyType",version="1_6")
def _get_timeseries():
next_cursor = None # Initialize the cursor as None at first
all_data = [] # List to hold all results
while True:
# Construct the query with the current cursor
query = Query(
with_={
"PropertyType": NodeResultSetExpression(
limit=10000,
filter=HasData(views=[view_id_1])
select={"PropertyType": Select([SourceSelector(view_id_1, properties=['*'])])},
cursors={"PropertyType": next_cursor}
result = cognite_client.data_modeling.instances.query(query)
if "PropertyType" in result.data:
all_data.extend(result.data["PropertyType"])
next_cursor = result.cursors.get("PropertyType", None)
if not next_cursor:
return all_data
start_time = time.time()
data = _get_timeseries()
end_time = time.time()
print(len(data))
print(end_time - start_time)
##Output
# 138205
# 82.43460583686829
- Pygen SDK
config = {
"credentials": {
from my_domain.client import MyClient
pygen_client = MyClient(client)
def _get_property():
return pygen_client.property_type.list(limit=None, retrieve_connections='skip')
data = _get_property()
print(len(data))
##Output
# 138205
# 82.43460583686829
Looks like an issue in the pygen sdk. Can this be looked into.
Check the
documentation
Ask the
Community
Take a look
at
Academy
Cognite
Status
Page
Contact
Cognite Support
