We wanted to use view filter to implement a new view in a datamodel with a subset of data. we wanted to filter on a property with external id “WELL”
we tried this in a few models, and we get only 70 instances, but when we try to query instances with same filter in transformations sql query, graphql query or rest api endpoint for filtering instances we get 71.
even in data modeling ui, when same filter is applied on original model, it shows 71 instances but one fo them shows up as empty
UPDATE:
the one that was missing in data model UI is because that well instance doesn’t exist in that space (only 70 wella in that right space). but when we query the same data model instances from rest api , it gives that well from different space as well (71 wells). it gives well instance along with WELL type from other space which actually does not exist
