Hello,
I’m trying to pull energy usage data from a Rockwell power monitor that supports OPC-DA but not OPC-UA. I configured the OPC-DA server (rslinx classic in this case) and I’m able to see the live data using an OPC-DA client (Kepserver). Next I try running the extractor, and it sees the project structure and creates assets, but never creates any time series data. I’m seeing very little in the logs. I did notice that “contious: False” shows up, but I don’t see any way to change that via configuration. I will get a keep alive message as you can see in the second image, but no data. Any suggestions would be greatly appreciated! Thank you.
