Wildcard (*) search
  • October 24, 2024
  • 74 views
Johan Herman Storm
Why do I get a long list if results when I search for “SKAP_20PIC0035*”, and why doesn’t it only search for wildcards after ...35 ?
Best answer by Arun Arunachalam
Hey ​@Johan Herman Storm this is intended behaviour . We understand that this may not necessarily help you find your data quicker today so i have put in a request for a feature improvement on the search algorithm and is something that is something that will be solved in the roadmap 😀. Essentially the goal here is to narrow down on results the more entries you put in order to help you find your data quicker especially with specific tags etc. Hope that helps !
Forum|alt.badge.img+8
@Johan Herman Storm I’ll check on this with the engineering team and get back to you with an update.
I didn’t know it was possible to filter using wildcards in CDF. Is this a new feature? I think CDF searches by Fuzzy Match, right?
Johan Herman Storm
That explains it :-)
Arun Arunachalam
  • November 25, 2024
Johan Herman Storm
Thank you :)
