API v1 using Postman
  • September 15, 2022
  • 6 replies
  • 175 views
I am following the course “Introduction to API v1 using Postman” and I am currently trying to get Access token using provided details in the lab unable to get the Access token when i click on “Get New Access Token” after that in a popup window I get an error message saying “Sorry, but we’re having trouble signing you in.”.
I am unable to move further due to this.
attaching the error log along with the details used :
Please suggest for this.
Best answer by Rahul Kumar
Hi Shilpa,
As I can see in the snapshot, you have define the variable like  baseUrl and it should be baseURL  and save the variable and run again.
Looking forward to hearing back form you.
Regards
Kumar
Forum|alt.badge.img+6
Hi Shilpa,
Thanks for your you details explanations.
Can you check if you have define the base url in the variable set up like “baseURL,  type = default and current value = https://api.cognitedata.com
We would like to know that, are you using the same account that you have used to login to hub ?
Does it help and looking forward to hearing back from you.
Regards
Kumar
Hello Rahul,
Yes, I have added the below env. variables as mentioned in the course :
Also in postman i haven't logged into to any account unless asked , but before entering any credentials its showing me the error.
Thanks & Regards,
Shilpa
  • September 16, 2022
Hi Shilpa,
Regards
Kumar
Hello Rahul,
Found the mistake the env. variable was getting added in other environments after adding it to right congnite-publicdata env. it was successful.
Thanks for you help Rahul!
shilpa
I am following the course “Understanding Open Industrial Data” and am at “Set up Postman”.
Two issues:
  1. I don’t get to see the “Authorize using browser” option under CallbackURL” and hence it is not allowing me to make any edits there as per the course. Just fyi, I am running the Postman from web and have downloaded  Postman-Agent for it.
  2.  I am currently trying to get Access token using provided details in the section. But I am unable to get the Access token when I click on “Get New Access Token”. I get an error message saying “Sorry, but we’re having trouble signing you in.”.
I am unable to move further due to this. I have attached the screen-shots to show my entries in Postman and error message. Will highly appreciate assistance to resolve this and help me move forward.
Thanks,
Anindya Ray
  • December 5, 2022
Hi Ray,
My colleague @Madina Kholmatova  , have posted the answer here
You can follow the request there.
Regards
Kumar
