Upload Files in Cognite using Streamlit
HanishSharma
Hello Experts!
I am trying out a POC where I am creating a basic file upload utility in streamlit app that helps users to upload a file in streamlit which gets loaded in CDF Files.
I am trying to take use of the following function from the sdk and tried several ways like providing the upload_url as a ‘path’ variable but nothing worked.
Can someone suggest any workarounds on this?
client.files.upload("/path/to/file", name="my_file")
import streamlit as st
client = CogniteClient()
st.title("File Uploader")
uploaded_file = st.file_uploader( "Upload your file here...")
st.write(uploaded_file)
Best answer by Everton Colling
Hi @HanishSharma!
The files uploaded through Streamlit can be uploaded to CDF using BytesIO. You can read more about it here:
Here’s a minimal example that you can also refer to:
st.title("Upload files to CDF")
name = st.text_input(
    label="Select a name",
    value="My test file"
    "Choose a file",
    accept_multiple_files=False
if uploaded_file is not None:
    bytes_data = uploaded_file.getvalue()
    client.files.upload_bytes(
        content=bytes_data,
        name=name,
Everton Colling
  • 163 replies
  • July 5, 2024
Hi @HanishSharma!
    "Choose a file",
        content=bytes_data,
        name=name,
HanishSharma
  • 64 replies
  • July 5, 2024
Thanks @Everton Colling
At first it created a tabular format file which wasn’t getting downloaded as csv (original format).
But later I used mime_type = “text/csv” and it worked!
        external_id ="test_h",
        content=bytes_data,
        name=name,
        mime_type ="text/csv"
