Best practice for joining data in models
  • April 26, 2024
  • 127 views
I am creating a transformation where I am joining data from two different views/containers, where table B has a node reference to table A. I have tried to find documentation for this, but I have not found any so far.
Through friends and trial and error I have found two options, and neither seems to be performing well.
Example:
Type A {
Type B{
   A_ref: A
What I have found as possible solutions are to go through cdf_data_models and picking the externalId from the node-reference:
from cdf_data models(<spc>, <mod>,<ver>, “A”) as A join cdf_… as B on A.external_id = B.A_ref.externalId
Same as above, but join on a as a nodereference:
on B.A_ref = node_reference(<spc>, A)
Neither of these options seems to be documented anywhere, and I can’t find any other ways documented. The performance when reading when using these joins seems slow, even though I have set up a few indexes which should cover the different joins. This is also slower then when reading from RAW for a comparable data set.
Hi @hakon_be,
I hope the above information was helpful. I’m closing this topic for now. Please don't hesitate to create a new post if you have any further questions.
Arild  Eide
  • May 30, 2024
Hi @hakon_be
Sorry for the late reply!
Can you please have a look in the docs “Incremental data loading when using Data Modeling” to see if you can have transformation read only recently updated nodes?
Also, you can test a similar query to the API directly yourself to see how this performs. Using the Python SDK it would be something like this:
query = Query(     with_={         "B": NodeResultSetExpression(filter=filters.HasData(views=[viewB])),         "A": NodeResultSetExpression(from_="B", through=PropertyId(source=viewB, property="ref_A"), direction="outwards", )     },     select={"A": Select([SourceSelector(viewA, ["field1"])])}     # select={"B": Select([SourceSelector(viewB, ["ref_A"])]), "A": Select([SourceSelector(viewA, ["field1"])])}, )
client.data_modeling.instances.query(query = query)
Hi @hakon_be,
Did the information above help you?
  • June 11, 2024
Hi @hakon_be,
