Using the is_new() function in transformations with joins
  • March 19, 2024
  • 78 views
I am looking into using the is_new functionality in my transformations, but was wondering whether it will work in transformations where is use joins. If so, how would I write the query?
In addition, I heard that you are working on releasing functionality to use is_new when reading from data models. When will this feature be ready?
Thank you!
Sebastian
Hi Sebastian,
Thank you for reaching out! What type of data are you looking to join, and what is your particular use case here?
Is_new is available for reading from data models. You can see more details here: https://docs.cognite.com/de/cdf/integration/guides/transformation/write_sql_queries/#incremental-data-loading-when-using-data-modeling
All the best,
Kat
