Authentication Issue: While trying to use 3D models through cognite/reveal
  • February 13, 2024
  • 60 views
I have solved the BufferGeometry issue was present earlier, apparently the react-app-wired was not the latest which is why the override was not working.
import React, { useEffect } from "react"
import { Cognite3DViewer } from "@cognite/reveal"
import { CogniteClient, CogniteAuthentication } from "@cognite/sdk"
import { getToken } from "../../utils/MsGraphApiCall"
import "./Models.css"
function Models() {
  const appId = "KPI-Dev"
  const project = "celanese-dev"
  const clientId = "my-client-d"
  const tenantId = "my-tenant-id"
  const cluster = "az-eastus-1"
  const modelId = 7575155737800092
  const revisionId = 3624517118008353
  async function start() {
    await client.authenticate(clientId, tenantId, cluster)
    const viewer = new Cognite3DViewer({
      sdk: client,
      domElement: document.querySelector("#your-element-for-viewer"),
    viewer.addModel({ modelId: modelId, revisionId: revisionId })
  const legacyInstance = new CogniteAuthentication({
    project,
  // getToken()
  const getToken = async () => {
    await legacyInstance.handleLoginRedirect()
    let token = await legacyInstance.getCDFToken()
    console.log("Token: ", token)
    if (token) {
      console.log("Token: ", token.accessToken)
      return token.accessToken
    token = await legacyInstance.login({ onAuthenticate: "REDIRECT" })
    if (token) {
    throw new Error("authentication error")
  console.log("TOken: ", getToken())
  const client = new CogniteClient({
    appId,
    project,
    getToken,
  useEffect(() => {
    start()
  }, []) // Empty dependency array to ensure it runs only once after mounting
  return <div id='your-element-for-viewer'>Models</div>
export default Models
But, now when I try to connect to cognite/reveal using the project, appId and all other details. The server responds with
This api.cognitedata.com page can’t be found
I’m attaching the component’s source code from where I’m trying to connect to cognite. And I would appreciate if I can be enlightened with a way to work this out.
A help would be highly appreciated.
Image attached below for reference.
Error Image
Thank you
Hariharan
Hi @Hariharan B P ,
I hope your issue was addressed in this post. If you have further questions please feel free to create a new post.
Hi @Hariharan B P ,
