Transformation to Numeric Data
  • March 3, 2023
  • 96 views
Chris Selph
I’m trying to transform some time-series data (manufacturing pump pressures) into Asset Hierarchy/Numeric Data.
The SQL is not writing to the timestamp column and not seeing errors in Preview.
I’ve tried MANY different SQL commands to convert the DateTimeStamp string column to timestamp column/datatype and none have worked.
CSV files are attached if anyone wants to try it.
Added query in attachments.
Help is greatly appreciated!
Transform setup:
Here is some of my data being edited in Excel and saved as CSV then imported into CDF Raw.
TagID Tagname Value DateTimeStamp
FCE1-HYD-PMP-3 FCE1-HYD-PMP-3 NULL 3/2/2023 3:41
FCE1-HYD-PMP-3 FCE1-HYD-PMP-3 28.54443 3/2/2023 5:51
FCE1-HYD-PMP-3 FCE1-HYD-PMP-3 35.68053 3/2/2023 5:51
FCE1-HYD-PMP-3 FCE1-HYD-PMP-3 42.81664 3/2/2023 5:51
FCE1-HYD-PMP-3 FCE1-HYD-PMP-3 49.95274 3/2/2023 5:51
RAW
Best answer by Gaetan Helness
Hi Chris
Since your input date format is not consistent, we need to deconstruct the date and rebuild it
  to_timestamp(
--- concat day,month,year,hour,minutes,second according to the expected format
concat(
-- get the day (first element split on "-") and append 0 if necessary
lpad(split(DateTimeStamp, "-") [0], 2, 0),
-- get the month (second element split on "-") and append 0 if necessary
lpad(split(DateTimeStamp, "-") [1], 2, 0),
-- get the year (third element split on "-" before the space) and append 0 if necessary
lpad(split(split(DateTimeStamp, "-") [2], " ") [0], 4, 0),
-- get the hour (first element split on ":" after the space) and append 0 if necessary
lpad(split(split(DateTimeStamp, " ") [1], ":") [0], 2, 0),
-- get the minutes (second element split on ":" after the space) and append 0 if necessary
lpad(split(split(DateTimeStamp, " ") [1], ":") [1], 2, 0),
-- get the seconds (third element split on ":" after the space) and append 0 if necessary
lpad(split(split(DateTimeStamp, " ") [1], ":") [2], 2, 0)
"dd-MM-yyyy hh:mm:ss"
) AS timestamp,
This code will split your date into individual blocks (day, month, year, hours, mins, seconds), append 0 if necessary and then format the date accordingly.
There could be a faster way, but I am not aware of it and if anyone has a better and cleaner solution, feel free to suggest it
Gaetan  Helness
Hi Chris
  to_timestamp(
concat(
) AS timestamp,
Chris Selph
  • March 6, 2023
@Gaetan Helness thank you for this solution. I found some help who suggested this which seems to work.
to_timestamp(DateTimeStamp, 'M/d/yyyy h:mm') AS timestamp,
I do not know why but the seconds (ss) do not appear to be present in the Raw table (but existed in the CSV) so I omitted the ss from the format in the transformation which satisfied it.
Your solution may be helpful in other situations for me and others so thanks again!
Chris
Gaetan  Helness
Great to hear you found a solution :)
And thanks for the update
