Learn to Use the Cognite Python SDK in the data engineer course
  • March 24, 2025
  • 45 views
so in the Learn to Use the Cognite Python SDK  in the data engineer course , I got stuck on the hands on test.as   in the readme file after I created a dataset and a root assets I just do not know how can I  do this section :
- Read the `all_countries.csv` file as a dataframe and list all the unique regions in the world.
- For each geographical region, create a corresponding CDF asset that is under the "global" root asset and is associated with the "world_info" data set.
- Next, create country-level assets using the data from the CSV and link them to their corresponding region-level assets.
Best answer by Ali-Akram
Thank you I got the problem solved. I do not know why but the code was not running for some reason but it worked fine after trying it with a new copy of the repository
Sofie Haug
Forum|alt.badge.img+12
  • Cognite Academy Instructor
  • March 25, 2025
Hi ​@Ali-Akram
Where did you get stuck? and what error message or similar it you receive?
  • March 25, 2025
