Azure Pipeline
Hi Team
I am working on cognite  Functions and  we have 3 cognite instances now,
Tiger-training
Demo-dev
demo-prod
I have created the pipeline such a way that it is built and deployed with the single run and it is pointing to either of the instance based on the credentials provided in azure.pipeline.yaml file.
functions-deploy-azure-pipelines/azure-pipelines.yaml at main · cognitedata/functions-deploy-azure-pipelines · GitHub
I am using the same pipeline file which is mentioned in the above link
So now my requirement is to build a separate build pipeline  that will build our cognite functions code, it builds and zips the
Cognite functions and create separate release pipeline for  and Deploy the zipped functions code to 3 different instances independently.
Please help me on this as it is a show stopper for us,
please set up a call anytime before 9 pm today and after 10.30 am tomorrow.
Nidhi N G
Best answer by N G Nidhi
Hi @Anita Hæhre  , I am able to deploy my functions to 3 different instances using a single pipeline.yaml file.
I am attaching the pipeline.yaml file here so that it will help others to have a reference.
Thanks for the support.
Nidhi N G
Murad Sæter
This setup is not supported by our pipeline action. It will build the zip file and create the function in the same codebase.
What’s the value of doing it with a single zip file? The contents of the zip file will the same when ran on the same source code.
Not sure I fully understand the question, but if you need to deploy to separate projects, I guess you can add multiple “Deploy Functions to CDF” steps in the pipeline, each pointing to different secrets/clientID/tenantID
Forum|alt.badge.img+6
  • March 29, 2023
We want to deploy the function in automated fashion in lower environment (e.g dev-CDF project , test CDF -project) from the single code base, and for deploying to production we want to manually execute release pipeline (based on our CR approvals and process). We will be tagging the master/main (version control) for  production deployment after we test in test CDF  project
We want to isolate CD(release) from CI(build) pipeline
I think you should be able to do that by having a different pipeline trigger, for example deploy to test with a "pull request trigger", test it and merge it to master after approval which would then deploy to production
  • April 13, 2023
Hi @N G Nidhi @jaydeep just checking in to see if you could use more information from us with regards to the above, or if you’re all good for now?
Nidhi N G
  • April 18, 2023
Hi @N G Nidhi, thanks so much for sharing with the community! 🙌
