In Data management / Integrate / Transform Data you can create and edit SQL code to transform your data.
Is it possible to backup/synchronize those code with github?
I am thinking about possible proliferation and duplication of many transformation pipelines, repeated code snippets, have to correct /update the same code in multiple transformations.
Thanks!
