type SimulationModel {
modelName: String!
nodes: [SimNode]
type SimNode {
modelName: String
input: [Key]
type Key{
modelName: String
unit: String
With the above sample schema, I am able to fetch all the SimNodes together with their Keys for a specified SimulationModel instance using the GraphQL:
query MyQuery{
listSimulationModel(filter:{externalId: {eq : "00000000-0000-0000-0000-000000000000"}}){
items {
externalId
modelName
nodes(first:100){
items{
externalId
modelName
input{
items{
externalId
modelName
unit
How to do do the same with the APIs, could you give an example? Not sure which API should be used(instances/list, instances/byids, instances/search, instances/query).
