Closed
InField 2.0: Support for Fuzzy Search on Checklist/Template Names
Related products:InField
  • February 18, 2025
  • 0 replies
  • 15 views
  • Anita Hæhre
hasitha malinga
A user (mark_wrzyszczynski@oxy.com) from Oxy requested for fuzzy search support in InField. Currently, when searching for checklists in InField, it appears that the search functionality only supports matches from the beginning of the string. It was observed that the Templates Search does not seem to support proper fuzzy search functionality.
For example, when searching for a template named 'Testwww'. While the search results are displayed when using the keyword 'Test', no results appear when searching with 'www'. The assumption is that the current search implementation may not be handling partial matches or keywords that are not at the start of the template name.
The requirement would be to enable partial/fuzzy search in InField for Checklist/Template name searches.
