Learn Cognite 3D Model
Learn Cognite 3d model, focus object, fit camera, search assets highlight object etc..
Best answer by Lars Moastuen
pramod.s wrote:
To focus at a clicked object in Reveal, you can do
  1. Get “Point intersection with the object” using Cognite3DViewer.getIntersectionFromPixel(offsetX, offsetY).
  2. Create a bounding box around intersection point like
    const boundingBox = new THREE.Box3();
    boundingBox.setFromCenterAndSize(intersection.point, new THREE.Vector3(1, 1, 1));
  3.  Use this bounding box in Cognite3DViewer.fitCameraToBoundingBox()
    viewer.fitCameraToBoundingBox(boundingBox, 250);
Note that rather than using bounding box directly from the CDF API, it’s recommended to use https://cognitedata.github.io/reveal-docs/docs/api/classes/cognite_reveal.CogniteCadModel#getboundingboxbynodeid to get bounding box for a given node as this accounts for any transformation active on the model.
  1. How to search object through assets ?
  2. How to focus object?
How to use fitCameraToBoundingBox method? please share some info.
https://cognitedata.github.io/reveal-docs/docs/api/classes/cognite_reveal.DefaultCameraManager
  • 15 replies
  • February 8, 2023
Lars Moastuen
  • 68 replies
  • February 8, 2023
thank you so mush, its working
  • 15 replies
  • February 9, 2023
Karthik Kaliyaperumal wrote:
https://cognitedata.github.io/reveal-docs/docs/examples/click-reactions-cad
How to enable and disable mouse click event?
The documentation page you referred https://cognitedata.github.io/reveal-docs/docs/examples/click-reactions-cad/ shows how to enable mouse click event “viewer.on(‘click’, callbackFn)”, to disable, unsubscribe the event using “viewer.off(‘click’, callbackFn)”
Hey, seems to be a small bug in our documentation. You need to await the viewer.add360ImageSet(...) method as it returns a promise.
I add await but again error comming.
  • 15 replies
  • February 10, 2023
Can you confirm if 360 images are loaded?
It return empty object.
I have 3d Model
I try to achieve add circle then click rotate camera.
Which version of Reveal are you using? Image360Collection.on(...) was recently introduced in Reveal 4.1.0.
My version is  "@cognite/reveal": "^4.0.0",
Ok, please update the dependency (as yarn.lock / npm.lock may still have 4.0.0 set).
please share sample code.
Documentation covering 360 images can be found here: https://cognitedata.github.io/reveal-docs/docs/examples/image360
1.what is site_id ?
2.how to find site_id?
  • 15 replies
  • February 13, 2023
1.what is site_id ?
Documentation about 360 images data is available at https://docs.cognite.com/cdf/3d/guides/360images_upload/, you will find required details related to site_id & more about 360 image data
Hi. Please share image uploaded site_id.
Lars Moastuen
  • 68 replies
  • February 14, 2023
Unfortunately there are no 360 images available in the demo project currently.
ok, thanks
  1. I would like to know how an Asset id is connected to its respective 3D model
  • 15 replies
  • February 16, 2023
Details of CDF assets with 3D models is available in documentation at https://cognitedata.github.io/reveal-docs/docs/api/classes/cognite_reveal.AssetNodeCollection/
Assets API
https://docs.cognite.com/api/v1/#tag/Assets
3d Model API
https://docs.cognite.com/api/v1/#tag/3D-Models/operation/get3DModels
I have assets id, The Assets id connected to its respective 3d model
Please share Which API I call.
