Parked
Make CDF data sources compatible with Grafana alert
Related products:Other
  • February 13, 2023
  • 99 views
Andre Alves
Isha Thapliyal
  • Andre Alves
    Andre Alves
  • Isha Thapliyal
    Isha Thapliyal
We are making grafana dashboards for our customers to monitor their data. It would be great to be able to make alerts for them so that they can see it in their dashboard. For this we need CDF data sources to be compatible with grafana alert.
Knut Vidvei
  • 132 replies
  • February 13, 2023
Hi, Zahra.
Thank you for raising this. We’d like to support as many features in Grafana as possible.
Unfortunately, this would require a complete rewrite of the Grafana plugin in another computer language than what we are using today, since it's only "backend" datasources in Grafana that support Grafana Alerting.
Based on the Grafana documentation: https://grafana.com/docs/grafana/latest/alerting/fundamentals/data-source-alerting/
If you are creating your own data source plugin, make sure it is a backend plugin as Grafana Alerting requires this in order to be able to evaluate rules using the data source. Frontend data sources are not supported, because the evaluation engine runs on the backend.
Best regards, Knut
Knut Vidvei
  • 132 replies
  • February 22, 2023
NewParked
  • Elkem
  • May 30, 2023
Hi! We have identified similar needs to set up alarms for CDF in Grafana. Is this something Cognite with put on agenda in the near future?
Michael Lis
Active
Hi All, this is something that we would also like to implement and set up alarms for CDF with Grafana. Can we sign-up and push this as an initiative for the future?
Are there other methods of reporting and alerting with CDF?
Thank you,
Michael
SLB
