Database named "_cdf" in the training
While going through CDF fundamental course and working with the hands-on exercise, I came across the transformation SQL which uses _cdf database and I have seen 2 different tables (assets and timeseries) used in 2 different transformations. Can someone please help a bit more on this _cdf database? What is it’s content, what all tables it contains, how is it created, to which all datasets this DB will be related to etc.
Best answer by Ben Petree
Hey checkout this part of the documentation.
https://docs.cognite.com/cdf/integration/guides/transformation/write_sql_queries#read-from-other-cdf-resource-types
This shows all the different tables you have available in the _cdf database. If you do a select * you will find that every column corresponds to a property for that resource type. All data that has been transformed into CDF resource types (asset, timeseries, etc) is queryable this way. You will have the same access and permissions to this data as your user. If you don’t have access to assets in a dataset because you aren’t in that group, then you won’t have access to them through the query.
Ben Petree
  • 19 replies
  • August 10, 2023
  • 223 replies
  • August 16, 2023
Hi @vsanwaria, did the above help you?
