I came across this documentation regarding how we can use GQL to override the type of direct relation when using a CDM feature.
Is there a similar documentation to highlight the changes needed to be made in the YAMLs when using CDF toolkit to deploy our model?
Please note that I tried dumping the working GQL, but the resulting yamls did not work when tried the other way around.
Override type for direct relations
Best answer by Anders Albert
If you use the Cognite-Toolkit, and run `cdf modules init` and select any of the models all of them show an example of overwriting the source.
