Python SDK
Pablo Palacios
Hello:
Please share some code example in python sdk to link a file to an asset.
thanks
Best answer by Andre Alves
I did not have time to test it, but according to the Cognite documentation, you can use FileMetadataUpdate instead of updating directly as I mentioned before. Below is an example from the Cognite documentation on how to attach labels. In your case, you can replace labels with asset_ids as the parameter.
Attach labels to a files:
>>> from cognite.client import CogniteClient
>>> from cognite.client.data_classes import FileMetadataUpdate
>>> client = CogniteClient()
>>> my_update = FileMetadataUpdate(id=1).labels.add(["PUMP", "VERIFIED"])
>>> res = client.files.update(my_update)
The documentation is available here: https://cognite-sdk-python.readthedocs-hosted.com/en/latest/files.html
Andre Alves
Forum|alt.badge.img+13
# Initialize the CogniteClient
client = CogniteClient(api_key="your_api_key", project="your_project")
# Define the asset ID and the file ID
asset_id = 123456789
file_id = 987654321
# Link the file to the asset
client.files.update(id=file_id, asset_ids=[asset_id])
print(f"File with ID {file_id} linked to asset with ID {asset_id}.")
This represents the metadata for a file. It does not contain the actual file itself. This is the read-only version of FileMetadata and is used when retrieving data from CDF.
I haven't had time to test it, but based on the documentation, it should work. I will test it later, but if it works for you, let me know as well.
Pablo Palacios
@Andre Alves thanks but it gives me the error:
TypeError: FilesAPI.update() got an unexpected keyword argument 'id'
and add the library:
Andre Alves
  • MVP
  • 147 replies
  • July 3, 2024
Pablo Palacios
@Andre Alves
Your last code worked well for me with the recommendations you give, thank you very much
Andre Alves
Good to know! I hope you are doing well with your challenges. See you soon!
