ValueError: Out of range float values
Forum|alt.badge.img+4
Doing the ‘hands-on’ for Data Engineer Basics - “Learn to Use the Cognite Python SDK “ Course."
I am down to adding events to CDF from  events.csv.
I noted that the dataframe df has some entries :NaN” wherever the csv has a blank.
Then,
However, creating events in CDF fails:
the error is:
Next, I replace all the csv blank entries with text “blank”, and read into a dataframe. Now the latter does not have any “NaN” values.
This throws the same exception when creating events in CDF.
If someone can kindly assist, I would be very grateful.
Thank you,
Doug
Best answer by Sofie Haug
We have made some changes to the course @Mugless Durry ! Please let me know if you still experience the same issues.
Sofie Haug
Forum|alt.badge.img+7
  • Cognite Academy Instructor
  • 151 replies
  • May 24, 2024
Hi @Mugless Durry, sorry for the late reply. I will have to go through the course myself and dig a bit into it to check, and if this causes any issues, I will make the needed changes to the events data.
Sofie Haug
  • 151 replies
  • June 6, 2024
