How to load sequences from a dataframe in batches?
Hi everyone,
I'm loading sequences from a file that has 11 million rows, and I would like to load it in batches, where each batch is a dataframe. As I load by batch, the rows that the sequence already had are being deleted, leaving only the last batch. How can I load each batch without deleting the previous one?
This is the code I use to read the file in batches and load rows into the sequence. It is assumed that the sequence is already created.
Karina Saylema
@Aditya Kotiyal  @HanishSharma  @Jason Dressel  @Jairo Salaya @Liliana Sierra
Best answer by Andrian Gasper
Hi @Karina Saylema
Your code seems correct.
Could you make sure that “row_number” is unique?
If you try the code bellow, are you encountering the same issue?
batch_size = 10000
external_id = 'TEST_UPLOAD4'
start_row = 0  # Initialize a starting row number
for chunk in pd.read_csv(file_input, sep=';', chunksize=batch_size):
    chunk.drop(columns=["row_number"], inplace=True)
    chunk.index = range(start_row, start_row + len(chunk))
    client.sequences.data.insert_dataframe(chunk, external_id=external_id, dropna=False)
    start_row += batch_size
Andrian Gasper
Hi @Karina Saylema
batch_size = 10000
  • 285 replies
  • April 2, 2024
@Karina Saylema
I think what’s happening is that chunk.set_index() is resetting the index for each chunk which is resulting in the sequence rows being overwritten because the row indexes are the same as the prior batch.
I’m not a pandas expert, but something like explicitly setting the index based on your batch size might be what you are looking for: https://pandas.pydata.org/docs/reference/api/pandas.RangeIndex.html
Hope this helps,
Jason
Thanks @Andrian Gasper, @Jason Dressel for your help
Andrian Gasper
@Karina Saylema You can mark this questions as answered, if you believe it is. :)
