state for OPC-UA extractor
Hi There,
How do you configure the state of OPC-UA extractor in the Raw layer?
I know that you can do it through various types of state stores including InfluxDB or local, but I have a dataset and a table in the Staging area which I would like to get populated.
Thanks in advance!
Best answer by Viraj Dhanusha
Hi Ghassan,
I’m Viraj from Support and I am not sure whether I understood your question correctly.
But the state store is defined as a local LiteDb database or a table in CDF RAW that stores various persistent information between runs.
It can be used as a replacement of the potential process of reading first/last data points from CDF, and also allow storing first/last times for events.
This is a guide how to use the state-store in the OPCUA extractor : https://docs.cognite.com/cdf/integration/guides/extraction/opc_ua/opc_ua_configuration#statestorage
Refer to this guide and if you have questions about it, please contact Cognite support via support@cognite.com
Viraj
  • 20 replies
  • November 29, 2023
Hi Ghassan,
Viraj
  • November 29, 2023
Thanks Viraj,
I am now able to follow the guide and correctly setup the Raw state store.
Ghassan
