Query to get column name from different table stores as column value
We have data model with
type abc{id: String
kind: String
description: String
key: String}
In other table , we have these columns stored as column values
kind attributes
1.0.0 name
1.0.0 description
1.0.0 key
1.0.0
name
need query to join on column value(stored as rows) from one table with solution model table data can group on by id or kind? As there can be n number of attributes, if we can do it dynamically to match column  value with column name.
Any help would be appreciated
Hi @Rimmi Anand,
I’m closing this topic now, please feel free to create a new post if you still experience problems.
joar.saether
  • Director Site Reliability Cognite
  • 6 replies
  • October 28, 2023
Hi Rimmi,
Can you add a little bit more context to your question?
  • Is the table you mention here stored in RAW?
  • Is the query you want to create going to run in transformations?
  • Is the purpose to create new instances from the table?
  • November 9, 2023
Hi @Rimmi Anand ,
If this request is still valid, please provide the required information. We are happy to help you.
  • November 22, 2023
Hi @Rimmi Anand,
